11/28/2018 6:33 PM | |
Joined: 6/4/2010 Last visit: 9/30/2024 Posts: 387 Rating: (128) |
Dear forum member,
I guess that you need a sensor for HVAC / Building Automation, as the posting is under Building Technology, Desigo. I therefore strongly recommend to use the HIT tool (HVAC Integrated Tool) to select the suitable sensors for your specific application. Link to the HIT tool (HVAC Integrated Tool) landing page: https://www.buildingtechnologies.siemens.com/bt/global/en/support/tools/pages/hit.aspx Please select your specific country to see the local offering. You may use the link below for the international version: https://hit.sbt.siemens.com/RWD/app.aspx?RC=HQEU&lang=en&MODULE=HitBase&ACTION=OpenPage&KEY=Home Please navigate: -> Product selection –> sensors -> humidity than use filter: “Temperature and Humidity”. You may apply further filter criteria’s based on your specific needs.
HIT will relieve you of routine tasks and time consuming search for suitable control devices, when designing HVAC plants. This simple and intelligent tool will enable you through an intuitive sequence of steps to select and document any HVAC control device as an individual product or in a system configuration. Using its library of over 300 preconfigured HVAC applications for standard controllers (Synco™, Sigmagyr™, Thermostats and Room Controllers (RXB/DXR2). HIT will generate for you a comprehensive specification including a plant diagram, list of material, technical documentation for each device, as well as pricing. Best regards, Albis |
11/29/2018 6:52 AM | |
Joined: 6/19/2017 Last visit: 9/6/2024 Posts: 8175 Rating: (172) |
Closed cause question posted twice.
