7/7/2010 7:30 PM | |
Joined: 1/17/2006 Last visit: 4/3/2025 Posts: 554 Rating:
Hello, I´m trying to configure and control the Temperature Channels using LADprogram instead ST program. I found in Technology > Temperature Channel some commands, but not all ST commands listed in the manualposted byChristophare available in LAD (Command Library), for example, I could not find the_FC_TC_setActive command in LAD. What is thefield"commandid" in the _settcontrolleroperatingmodeLAD command ? I did not understand the manual explanation ! Best regards, Berg |
"Educate the children and it won't be necessary to punish the men." |
7/7/2010 7:56 PM | |
Joined: 7/6/2010 Last visit: 11/25/2022 Posts: 21 Rating:
Hello The commandId is for identifya system function, maybethe example attachhelp you The _getcommandid function is in the command library Technology --> Common functions best regards AttachmentCommandID.zip (388 Downloads) |
