8/25/2011 6:57 PM | |
Posts: 9 Rating: (0) |
Addendum: i use 12 volt for my logo's does this make a difference? because i see a lot of messages with the am2pt100 where always 24 volt is used. |
8/25/2011 8:50 PM | |
Joined: 4/22/2010 Last visit: 11/18/2024 Posts: 5697 Rating: (715) |
Hello, The AM2 PT100 can run on 12VDC, so there must be something else wrong. Please check your wiring, because -50 is the minimum value of the AM2. Look at the manual for details: http://support.automation.siemens.com/WW/view/en/50074616 If wiring o.k. try all the inputs, one off them must be right Regards, Marcjan |
Problem solved? |
