3/1/2023 1:30 PM | |
Joined: 5/6/2022 Last visit: 4/22/2025 Posts: 587 Rating:
Hi AutoGen_8522401, Yes, the following FAQ is available in the SIOS where you can find template suites for V17 and the one for Comfort panels. "HMI design with the HMI Template Suite" Is this where you searched for it and downloaded it? However, it does not seem to be mentioned in the document that it is valid for TP1900 panels. I look forward to your answer. Best regards! |
