6/29/2018 10:29 AM | |
Posts: 2 Rating:
Hello, I'm trying to make get communication between S7 1200 and S7 300. I want the S7 1200 controller to read some bytes from S7 300. I have S7 1214 and S7 300 with CP 343-1 Lean.In the attahced file is what I had made. When I test the communication the S7 1200 PLC blinks several times in read and in diagnostic buffer is written: " Temporary CPU error: Area length error in OB 1....". You can see it in second picture on the right. ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 6/29/2018 11:16:56 AMNew subject after splitting |
10/19/2024 7:21 AM | |
Posts: 1 Rating:
Exactly Error was in which block ? Because i also have similar Problem. |
