12/13/2016 10:38 PM | |
Joined: 9/27/2006 Last visit: 4/19/2025 Posts: 12346 Rating:
Hello andrul My first thought would be dynamicText Lists, whuch are available in WinCC. However, TIA Portal does not let you activate the different texts using BOOLs; you need Index tags (INT variables) instead of Bools... See this article for more details: How do you create dynamic text lists in WinCC (TIA Portal)? https://support.industry.siemens.com/cs/fr/en/view/57025748 Hope this helps, Daniel Chartier |
12/14/2016 5:14 PM | |
Posts: 7 Rating:
Thanks for your answers :) I am using Step7 and WinCC in professional version, V13 sp1. PLC which I use is S7-1200, panel - Comfort Series |
