11/15/2021 5:25 PM | |
Joined: 9/24/2019 Last visit: 9/30/2023 Posts: 5 Rating:
Hi, The first batch I ordered and works fine is A5E43639217-AF The last batch I ordered in august and I'm using those today is the A5E43639217-AH. Could you explain me the difference ? The A5E43639217-AH is not booting from SD. Best regards, ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 11/16/2021 09:52:15New subject after splitting |
11/16/2021 2:28 PM | |
Joined: 4/28/2015 Last visit: 9/29/2023 Posts: 3261 Rating:
Hi, I requested the exact difference from R&D. But I guess the AH does contain the pre-installed Industrial OS on the eMMc. You can also check this on the label on the right hand side. FS:02 stands for the pre-installed IndOS. That's the reason why it does not boot from SD card, as the eMMc is set as first boot device and contains an OS. How to deal with that is described here. Best regards! |
