1/3/2008 5:38 AM | |
Posts: 17 Rating: (1) |
Hi Wizard, I think I know what should I do d.. Thanks!! |
1/3/2008 8:54 AM | |
Joined: 4/24/2006 Last visit: 7/12/2024 Posts: 8711 Rating: (1166) |
You are welcome |
1/16/2008 3:19 PM | |
Dear New_Bird, I'm going to try to answer.
I suppose you have CP342-5 as master , so you use GSD file for EM277. When you insert an EM277, you will have to insert Inputs and Outputs. I suggest you insert an 'Universal module'. Double click on it and you can insert In- and Outputs (20 word in and 20 word out)
This is the location where you store data from S7-200
Pleas have a look at following faq: http://support.automation.siemens.com/WW/view/en/18208090 See point 5 Best regards, Wizard |
