10/24/2022 3:00 PM | |
Joined: 7/19/2022 Last visit: 4/23/2025 Posts: 436 Rating:
Hi FilipKlajn, I think this is because if you are reading data from archived files from a USB or SD card, the trend data is not refresehed continuously, it is only refresehed when you open the trend, unlike when you read a variable directly from the PLC/HMI which is refreshed in real time. |
