2/17/2020 4:03 PM | |
Posts: 1 Rating: (0) |
Thanks, but after activate all of this windows services the installation of Wincc unified is blocked because is not compatible with WinCC Professional. I need a computer without wincc? ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 02/18/2020 05:50:48New subject after splitting |
3/16/2021 10:59 AM | |
Posts: 4 Rating: (0) |
So how do i fix this issue, i deleted wincc professional but it still has the error message? |
3/16/2021 11:07 AM | |
Joined: 5/12/2006 Last visit: 1/17/2025 Posts: 22497 Rating: (3044) |
check the registry that no WinCC Professional keys exists |
3/16/2021 1:18 PM | |
If I open the registry file it says "this map is empty". Do you have any other suggestions? |
3/16/2021 1:20 PM | |
?????which file? |
3/16/2021 1:22 PM | |
The registry or what other file are you talking about, where do i find it. I am new to the whole tia portal program |
3/16/2021 1:34 PM | |
i talk about windows registry! |
6/9/2021 4:40 PM | |
Joined: 5/7/2021 Last visit: 11/20/2024 Posts: 2 Rating: (0) |
I have the same problem. I can not install Unified because I had professional installed previously. Is there a fix to this? |
6/9/2021 5:25 PM | |
uninstall wincc professional |
