12/11/2020 3:44 PM | |
Joined: 10/11/2006 Last visit: 1/22/2025 Posts: 5985 Rating:
Hello, How can you realize the encoder configuration? https://support.industry.siemens.com/cs/ww/en/view/109486133 Manual SIMATIC Traversing Drive https://support.industry.siemens.com/cs/ww/en/view/109758582 |
With best regards, |
1/19/2021 2:01 PM | |
Hello, to analyze this problem we need further information. According to the error code description in the manual an error at the LTrav_AxisCtrl function block (probably during a change of the cam). This can be caused because of an error at the Traverser axis or an error at the camIn command. For further analyzation we need the value of the output “subfunctionStatus” at the LTrav_TravCtrl function block: subfunctionStatus = xxxx_8001
subfunctionStatus = xxxx_8000
For further information you can also contact us directly, please look at our contact data in our profile. |
