1/26/2022 7:43 AM | |
Joined: 3/2/2015 Last visit: 2/3/2023 Posts: 60 Rating:
Hi, As per S7-1200 System Manual the NI1000 is supported by SM1231 6ES7231-5PD32-0XB0 RTD module. The attached table shows the supported RTD sensors. However for the NTC probes if you have its calibration curve then maybe you can use it with RTD module, if not then maybe you need to replace those with PT100 or other compatible RTD probes. |
