5/24/2011 5:27 PM | |
Joined: 5/28/2008 Last visit: 9/9/2024 Posts: 4515 Rating: (839) |
Hello, I agree with Umencho on using a converter or you can replace the module by 6ES7 331-7PE10-0AB0.
Ayman Elotaify |
5/25/2011 12:52 PM | |
Joined: 4/22/2010 Last visit: 5/3/2024 Posts: 5697 Rating: (715) |
I think you can find that information here : http://www.omega.com/prodinfo/thermocouples.html Best regards, Marcjan |
Problem solved? |
5/26/2011 8:48 AM | |
Hello Amro, Please find here in(sec.6.7)ofS7-300 Module dataall wiring examples of 6ES7 331-7KF02-0AB0 module. Please do not forget to set the black squares in the side of the module to its correct position according to the AI type. And take into consideration that the AI module is 8 channels grouped in 4 groups. And have a look on the attached screen shot of the module.Set the measuring type and range in HW config. as explained in the picture. Hope this helps. |
Ayman Elotaify |
