3/27/2019 1:02 PM | |
Joined: 9/27/2006 Last visit: 3/14/2025 Posts: 12344 Rating:
Hello Andrivel; To use the S7 CPU as a Profinet IO device (I-device to another CPU), you must generate the GSDML file yourself. You will find the complete description of how to use a S7 CPU as an I-device in section 4.8 of the following manual: Simatic Profinet System Description : https://support.industry.siemens.com/cs/us/en/view/19292127 Hope this helps, Daniel Chartier |
3/27/2019 1:22 PM | |
Joined: 12/27/2018 Last visit: 8/16/2024 Posts: 45 Rating:
Thank. I found files for 317F-2. Is it possible to generate these files through Tiaportal 15?
3/27/2019 3:01 PM | |
Thank you very much. I also found this for my controller. Andrey |
