5/5/2021 4:16 PM | |
Joined: 10/28/2009 Last visit: 4/12/2025 Posts: 10 Rating:
Hello, Edit mode in recipe view doesn't work in TIA 15.1 anymore. When I press ENTER key after edit mode, it returns to previous width.In TIA13 it worked. I want to increase right margin of recipe view, because some values are trimmed from right side with slide bar indicator. It could help, if I can set center alignment of the column, but I don't know how. I found that you can set scrool bar mode in runtime setting. See https://support.industry.siemens.com/tf/es/en/posts/recipe-view-up-down-slider-too-small/115382?page=3&pageSize=10 It doesn't solve my problem but it helps to see whole fiield. Any suggestion? Jan ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 05/06/2021 09:16:44New subject after splitting Last edited by: Jan_Budweis at: 05/06/2021 11:05:01 |
