7/3/2012 12:58 PM | |
Posts: 69 Rating:
Yes created new project also same error. Done uninstall/ install same error. Please find the attached error log while installing the wincc again. Installation completed with the following error log report. I had done the repair, reinstallig but still while compiling showing the same error Thanks, Soju AttachmentSIA_WINCC_PROFESSIONAL_V11.zip (841 Downloads) |
7/4/2012 1:32 PM | |
Posts: 3037 Rating:
Hello, Do you use the right operating system for WinCC V11? You find the list of software on the end of this FAQ. With what is SIMATIC WinCC V11 compatible? You should check the software of your computer with this list. Tweety |
7/6/2012 6:03 AM | |
Posts: 69 Rating:
Hi Tweety, I am using Windows 7 Enterprise Edition and I checked the compatability too. Thanks, Soju |
7/6/2012 12:29 PM | |
Posts: 3037 Rating:
Hello, In this case, you should start asupport request on the customer support. ---> customer support Tweety |
