11/9/2012 5:22 PM | |
Joined: 7/7/2010 Last visit: 1/24/2025 Posts: 15556 Rating: (2467)
In cases like this, I think the best solution is to try : Support Request If you have not tried compile (rebuild all blocks) at least once, you should do that. If your project is quite large, what may have changed between the first time you created the block and now that now makes it crash? SCL blocks can create crashes. There is a new update, Update 5 that may help with the crash. I am guessing Siemens support would suggest you try that first. |
science guy |
