2/27/2015 7:46 AM | |
Posts: 1299 Rating:
Hello, you can't insert a datatype as a tag. but if you have a tag in the plc with this data type (e.g. in a db) you can use this tag as an hmi tag. K!ke |
2/27/2015 8:36 PM | |
Joined: 9/21/2006 Last visit: 1/27/2023 Posts: 241 Rating:
I have been looking at this feature this morning. As best as I can figure out, in WinCC Adv V13 SP1 Upd1, you can create an HMI tag of a PLC user data type tag that is access symbolically. I can create the tag, and access the tag using absolute addressing, but I haven't figured out a way to access the tag symbolically, even though the tag itself is in an optimized data block in the PLC. Screenshots attached. I am hoping that I just haven't quite figured out how to do it yet. AttachmentUDT_HMI_Tags.zip (709 Downloads) |
