7/14/2021 8:48 PM | |
Joined: 9/1/2016 Last visit: 2/13/2025 Posts: 18 Rating:
Hello: Sorry isf this isnt appropiate. I'm having a serius problem whit Tia Portal V15 when tryin to Load project to HMI. Tia portal IF doesnt show me the option to change PG/PC Interface. Im running Tiaportal V15 and WinCC Prof V15 as well. Both on my SO Windows10. Thanks for your advice. ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 07/15/2021 09:19:27New subject after splitting |
7/14/2021 10:02 PM | |
Joined: 9/27/2006 Last visit: 4/19/2025 Posts: 12346 Rating:
Hello; This little video from YouTube should give you good pointers to set the PG/PC interface: https://www.youtube.com/watch?v=Yotb03NvRlw Hope this helps, |
7/15/2021 9:13 AM | |
Joined: 5/12/2006 Last visit: 4/24/2025 Posts: 22601 Rating:
what happern if you click on conect in this dialog? |
7/15/2021 3:19 PM | |
this is normal for a basic panel, no way to select anything |
7/15/2021 3:23 PM | |
what you mean? |
7/15/2021 3:29 PM | |
maybe try extended download to device? |
