11/14/2011 12:26 PM | |
Posts: 24 Rating:
I forgot to say that "General connection error 0X320" appeared when I try to start runtime! |
11/17/2011 8:44 AM | |
Posts: 14 Rating:
Hi arecar78, Typ tekst of een websiteadres of vertaal een document. Vertaling van het Nederlands in het EngelsI had the same problem with Step 7 v5.5. I also installedTIA portal by first removing S7DOS. I solved this by using the same trick as I used during the installing of TIA portal. So first delete S7DOS and then reinstall Step 7 V5.5. Both programs work fine for me right now. But i didn't check online communication for TIA portal (only for step 7). Hope this helps. |
8/1/2014 7:32 AM | |
Joined: 9/1/2005 Last visit: 1/9/2023 Posts: 4097 Rating:
new question published bys.saravananis split to a seperate thread with the subject promblem in tia portal v11 during installing Best regards CS Moderator |
