10/8/2014 9:25 AM | |
Joined: 10/10/2005 Last visit: 1/29/2025 Posts: 1940 Rating:
Hello, the problem is, that you have installed the STEP 7 (TIA Portal) V11 or V12 on your PC and so after you can make the upgrade from V11 or V12 to STEP 7 (TIA Portal) V13. Otherwise you need the floating license of V13, if you have not installed the V11 or V12 on your PC. See the follow informations in the FAQ: http://support.automation.siemens.com/WW/view/en/57775228 You have STEP 7 Professional V11 or V12 installed on your computer and you want to upgrade to STEP 7 Professional V13.
It is not possible to use this upgrade to upgrade from STEP 7 Professional 2010. With best regards |
