4/18/2012 12:48 PM | |
Posts: 34 Rating: (0) |
hello i am new to TIA PORTAL. is it possilbe to convert protool runtime project to WinCC using TIA PORTAL? pl let me know. Thankyou. |
4/21/2012 8:54 AM | |
Joined: 3/21/2006 Last visit: 10/4/2024 Posts: 10229 Rating: (1181) |
Hello, Try it with writing 'TIA Portal V11 SP2' in search field here... Best regards, Hristo Mihalev
4/21/2012 2:33 PM | |
Posts: 510 Rating: (117) |
Checking the Updates for HMI Software/WinCC TIA Portal under Operator Contrl and Monitoring systems is another way to find it billwest |
4/23/2012 8:11 PM | |
Joined: 8/31/2010 Last visit: 9/30/2024 Posts: 1522 Rating: (228) |
Hello Chevli, You can make use of this Migration Tool for TIA Portal V11to migrate your projects, till you get your TIA Portal (as it works without TIA Portal v11 SP2 being installed). TIA Portal is not a product which you can order as it will not have any MLFB. If you want to purchase STEP 7 v11 (Safety) / WinCC v11then check the MLFB for various products from here. |
Like it? Rate it! |
