11/3/2014 4:28 PM | |
Joined: 7/7/2010 Last visit: 1/17/2025 Posts: 15541 Rating: (2465)
My last resort option will work and will probably be faster than using Support Requestand sending Siemens your project to find the problem. I would probably still send them my project so they can fix itin future portal updates. Hey, they might even point out the problem right away and help you figure it out yourself if it happens again when you choose to go deleting things without deleting the objects they are used in first. It is better from my experience to delete the screens and objects from screens, then find images that are not used anywhere, then delete only those unused items. I think that method is what Siemens anticipates and so they add options to support it. |
science guy |
