4/6/2017 6:29 PM | |
Joined: 8/31/2005 Last visit: 1/23/2023 Posts: 2194 Rating:
If the TIAP still crashes the project database may be damaged. Close and reopen TIA Portal and beginn with a new project. AttachmentScreenshots.zip (633 Downloads) |
4/7/2017 11:02 AM | |
Joined: 2/11/2014 Last visit: 9/19/2021 Posts: 40 Rating:
Hi miami; Thank you for reply; in my project PD_TEL3 not declared as PLC datatypes. Are you declare manually PD_TEL3? |
4/7/2017 2:29 PM | |
Yes, you must type it in manually when defining the DB. After this a few PLC-DataTypes are in the project. And don't forget to compile the DB before configuring the TO. I add my project. You will have to fill the encoder and drive status in the "Input" section of the DB in the OB PreServo. And use the "output" section of the DB in the OB PostServo. AttachmentForum.zip (619 Downloads) |
Last edited by: miami at: 4/7/2017 2:45:49 PMLast edited by: miami at: 4/7/2017 2:46:24 PM |
4/7/2017 4:11 PM | |
Thank you very much miami; |
9/8/2017 9:53 AM | |
Joined: 8/21/2014 Last visit: 1/30/2023 Posts: 696 Rating:
New question published by __quinn__ is split to a separate thread with the subject please give me a code demo using this way to control servo motor?. Best regards |
