1/31/2025 11:30 AM | |
Joined: 7/11/2024 Last visit: 4/16/2025 Posts: 185 Rating:
Hello, Yes, it is possible. You can check it in the next FAQ: What options are available in STEP 7 (TIA Portal) for uploading when the project version in the CPU no longer matches the version on your PG/PC? I hope it helps you! |
If this post has been useful, don't forget to rate it!😊 |
