6/17/2024 7:16 AM | |
Joined: 12/10/2021 Last visit: 9/5/2024 Posts: 19 Rating: (2) |
Hi, we also tried the option you suggested, but there is no way to start the simulation. |
8/7/2024 2:43 PM | |
Joined: 8/30/2023 Last visit: 9/5/2024 Posts: 1 Rating: (0) |
Hello, I have encountered the same problem when I upgraded to update 4. |
8/9/2024 8:09 AM | |
Joined: 8/3/2009 Last visit: 9/19/2024 Posts: 13730 Rating: (1728)
Hello do you already have installed not only the Upd4 for TIA Portal, you have also to install the Unified PC RT Update for simulation: https://support.industry.siemens.com/cs/de/en/view/109807123 Bye Murof |
