5/18/2014 8:11 PM | |
Posts: 784 Rating:
Hello, 1-Is it possible to download TIA trial versions V11 or V12 or V13 from Siemens site then activate it? 2-How? Best regards..... |
5/18/2014 8:20 PM | |
Joined: 1/28/2009 Last visit: 1/19/2025 Posts: 6858 Rating:
Please search for TIA Portal V13 Trial , and you can use it for 21 days SIMATIC STEP 7 (TIA Portal) V13 TRIAL Download |
5/18/2014 8:26 PM | |
Posts: 8946 Rating:
After licensing, this Version will run as full version? |
5/18/2014 8:34 PM | |
Posts: 784 Rating:
Hello, Where can we download TIA trial software V11 or V12? Best regards........ |
5/18/2014 8:57 PM | |
Posts: 784 Rating:
Hello, Thanks Hamid. As you expected,V12 is available to download http://support.automation.siemens.com/WW/view/en/77317911 But V11 is not available. Best regards.......... |
5/18/2014 9:15 PM | |
Joined: 8/31/2010 Last visit: 1/24/2025 Posts: 1523 Rating:
Hello Wago, You can use TIA Portal v12 and still continue to work (create new project, edit, compile, download) with your v11 project in compatibility mode. Download the v11 project which can be used in compatibility mode in v12. |
Like it? Rate it! |
5/18/2014 9:15 PM |
Like it? Rate it! |
5/18/2014 9:26 PM | |
Posts: 784 Rating:
Hello, Is it possible to use TIA Portal V13 to open a project programmed by TIA V11? Best regards..... |
5/18/2014 9:53 PM | |
Hello Wago, when you try opening your v11 project in v13, the project gets upgraded to v13. |
Like it? Rate it! |
