2/13/2012 11:32 AM | |
Joined: 8/10/2005 Last visit: 2/7/2022 Posts: 3609 Rating:
Import of a Technical Question of an User
2/13/2012 11:45 AM | |
Joined: 8/31/2010 Last visit: 2/3/2023 Posts: 1498 Rating:
Hello PREETISH KANAGALI, Yes of course both STEP 7 v11 and WinCC v11 is compatible with both 32 bit and 64 bit MS Windows 7 OS. Check the compatbility of the correct MS Windows 7 version (home / professional / ultimate) from here - Compatibility tool |
Like it? Rate it! |
2/13/2012 11:47 AM | |
Posts: 378 Rating:
Hello, this depends on your TIA-Portal Version Just see the following entry: http://support.automation.siemens.com/WW/view/en/51120883 Best regards Bilao |
2/13/2012 12:03 PM | |
Posts: 8 Rating:
i m having tia v11 update 1, and sp2, and tell which windows should i go for? 32bit windows 7 home or professional?
2/13/2012 12:10 PM | |
Posts: 378 Rating:
When having SP2 you can take what you want Utlimate, Professional, Home Premium and Enterprise are comatible with SP2. Just see the delivery release of SP2 Best regards Bilao |
2/13/2012 1:38 PM | |
Hello PREETISH, Take this into consideration without fail while you go for 64-bit Windows 7 OS.
