6/28/2014 1:16 PM | |
Joined: 7/15/2009 Last visit: 1/22/2023 Posts: 26 Rating:
i have a problem with wincc advanced V12. i am working in a scada project, and every page i make some modification and see it by run time simulation to check my project , yesterday i try to compile and go to run time , the project make the compile but can't enter thr run time and give me that bad message with make the wincc program to close ,, please advise me to find solution to solve this problem.
AttachmentTIA_problem.pdf (171 Downloads) |
6/30/2014 1:30 PM | |
Posts: 1299 Rating:
Hello, do you get this error everytime you try to start the simulation? Did you try itwith another project? K!ke |
9/8/2014 3:53 PM | |
Posts: 1299 Rating:
Hello, I faced this problem but it wasn't repeatable in my case. Restarting the TIA Portal solved it. in your case I would recommend you to start a support request, send them the diagnostic files so they can analyzie the prolem. K!ke |
9/8/2014 8:48 PM | |
Well Done |
