6/8/2011 3:42 AM | |
Posts: 510 Rating:
Here is a zip file with a project and the library in V11 format. In the project, OB1 compiled with the Fb144 com block, Good Luck billwest Attachmentgprs.zip (199 Downloads) |
6/8/2011 8:10 AM | |
Posts: 211 Rating:
Hi billwest, it does not work (as for me). I got the same result with your FB144,as I did yesterday. |
6/8/2011 2:26 PM | |
Posts: 510 Rating:
If you will post your code or send it to me, I will look at it. |
6/16/2011 3:51 PM | |
Posts: 211 Rating:
:) Billwest, here it is: http://support.automation.siemens.com/WW/llisapi.dll?func=cslib.csinfo&lang=en&objid=39863979&caller=nl upgraded to V11, officialy! Solved! Thanks! |
