9/11/2014 11:22 AM | |
Joined: 4/14/2010 Last visit: 11/11/2024 Posts: 525 Rating: (11) |
Greeting, I have read this procedure but not able to copy past the bloack from one to another project. Thanks. |
MS |
9/11/2014 1:31 PM | |
Joined: 1/5/2011 Last visit: 11/29/2024 Posts: 815 Rating: (123) |
Dear Sarfraz, can you describe in a bit more detail the problem you are facing? Do you get an error pop-up? Did you try copy/paste instead of drag drop? Doesthe synchronization window pop up (see attachment)? Opening multiple instance of tia portal and dragging your block from one project to another should work. A synchronization window pops-up upon copying (attachment). Kind regards, Jens |
Keep it simple and on-topic. |
9/11/2014 2:01 PM | |
Joined: 7/7/2010 Last visit: 12/3/2024 Posts: 15452 Rating: (2452)
The trick for me for pasting is to select your program blocks in the project you are pasting group heading and right-click to see the paste option. I use the right-click option in the right place in the project tree and the paste option appears. I use the right-click in the wrong place and paste is grayed out. |
science guy |
9/11/2014 2:40 PM | |
Dear Huggy_d1, Thanks for message, please see attached paste option not appear in project tree. Thanks AttachmentDesktop.zip (97 Downloads) |
MS |
9/11/2014 4:02 PM | |
Dear huggy_d1, With know how protection and SCL language restriction we are not able perform generate source option. and for creation the new global libray folder, icon dosn't allow this see attached please. Thanks. AttachmentDesktop.zip (100 Downloads) |
MS |
9/12/2014 7:54 AM | |
Dear huggy_d1 i have generate source file scl.scl file from copy project, i have utilized accordingly that was really helpfull, but not resolve the issue for complete project even after study of these method Drop/insert (0023: 000005) "the specified objects may not be copied to the current target.") error message appear. Thanks. |
