3/21/2016 10:02 AM | |
Posts: 13 Rating: (0) |
Me i have Tia portal pro V12 installed and have the following problem with sample project filling station. On page 84 step 10 of the manual says: "press the "return key" to confirm the selection of the "Global_DB". A window now opens for selecting data block tags witch have already created.". But once i done with step 9 and press the return key nothing happens, is someone who can help me with this?
Thanks in advance ------------------------------------------------------------------------------------------ |
Last edited by: Min_Moderator at: 3/22/2016 1:20:24 PMNew subject after splitting |
3/21/2016 3:35 PM | |
hier is the link for the Handboek Getting Started STEP 7 Professional / WinCC Advanced V11 for sample project Filling Station
thanks in advance |
3/21/2016 4:54 PM | |
Joined: 6/3/2014 Last visit: 9/26/2024 Posts: 660 Rating: (194) |
Hello Manthos, I think I'm too unfamiliar with the project and GRAPH, sorry. You should ask the question in another part of the forum: "Industrial Software > STEP 7 (TIA Portal)". Use this link, it's a shortcut to the chapter: https://support.industry.siemens.com/cs/ww/en/view/54430386/34948854539 You use an example for V11 in V12, it could be that the handling changed slightly and pressing enter isn't the correct way anymore.
4/20/2016 4:02 PM | |
Hallo H.J. thanks i review the program and i found a type fault in tags. sorry for the late reaction but so busy with work too...at this moment i reach the visualisation part of the program and is going fine so far. thanks or your advice
4/20/2016 4:06 PM | |
Hallo, u mention that u are not familiar with graph. do u have expiriance with creating programs in S7 manager in LAD for expample from A to Z? i am searching a sample program(s) en manuals to be able to create one. greetings
