12/8/2015 6:33 AM | |
Posts: 1 Rating: (0) |
Hi! I have very strange problem. I have tia portal v13 software & my operating system is windows 7 sp1. When I want to compile any hmi configuration it shows an error which is Tahoma font is not installed. But I check my front Tahoma is installed. Please help me. ------------------------------------------------------------------------------------------ |
Last edited by: Min_Moderator at: 12/8/2015 10:52:51 AMNew subject after splitting |
8/31/2016 1:35 PM | |
Posts: 22 Rating: (0) |
Did you get any solution for this siemens TIA portal error??? I have the same problem with TIA V13 SP1 Upd 9. HMI compilation stuck because a font not installed in OS, but it is. Any help will be appreciated.
Last edited by: andress at: 8/31/2016 1:47:03 PMLast edited by: andress at: 8/31/2016 1:47:49 PM |
9/2/2016 3:48 PM | |
Joined: 6/3/2014 Last visit: 9/26/2024 Posts: 660 Rating: (194) |
Hello andress, I found the follwing information: You might need to raise the access rights to the fonts directory/registry. Forum:
(Or maybe run this MS fix: https://support.microsoft.com/en-us/kb/886549) |
