4/15/2021 2:27 PM | |
Joined: 4/20/2010 Last visit: 4/23/2025 Posts: 47 Rating:
Hello all, I'm using TIAv16 Update 3, Windows 10 Pro. I'm facing the same issue : when I launch the runtime of a TP1200 Comfort, it works for 2-3 minutes, then I get the message in windows logs, I've the following :(sorry it's in french) Nom de l’application défaillante HmiRTm.exe, version : 1600.3.101.1, horodatage : 0x5f33af1a I tried to change the "firmware" of the TP : Nothing change, same issue Hope this can help TIA developers to solve this issue. In case you found the solution, I'll be happy to try it. PS : I did this with different projects, same issue. I did not have this with TIAv15... Thanks in advance for your help Edit : After investigations, the module "SYSTEM DIAGNOSTIC VIEW" makes the runtime to crash (but not the real Touch Panel) ! ------------------------------------------------------------------------------------------ |
Last edited by: seb_20 at: 04/15/2021 14:34:10Last edited by: seb_20 at: 04/15/2021 15:05:52Last edited by: Jen_Moderator at: 04/16/2021 08:44:53New subject after splitting |
