7/5/2023 1:53 PM | |
Posts: 4 Rating:
Hello all, As the title states, I'm having issues inside Siemens TIA Portal V18 trying to simulate the HMI screen with PLC Simulator. The "Start Simulation" button in TIA portal stays grayed out and does not allow me to click it. This is only the case though for unified panels, as I can successfully simulate non-unified panels. The only thing I have found on Siemens' website lists the file SIMATIC WinCC Unified RT PC V18 Simulation & Trial as required for simulating WinCC Unified Confort with TIA portals V18, but when I try to install this, I get the error it cannot run in parallel with my currently installed software. Am I missing something simple here, or is there a bigger issue not allowing me to simulate Unified Comfort panels inside of TIA Portal V18? For context, I recently installed V18 parallel with an existing installation of V17. My software list is attached below. |
Last edited by: CPATTY at: 07/05/2023 13:55:04Last edited by: Jen_Moderator at: 07/06/2023 08:34:34Link optimized. |
7/5/2023 2:16 PM | |
Posts: 4 Rating:
Would it help if I were to uninstall V17 entirely from the PC? I no longer have a use for it as I have V18 installed. |
