4/22/2024 11:53 AM | |
Hello CGMsrl I think if you use the ES as OS (so you want to load yourself) then you have to work with "Load to filesystem" And the FAQ you have mentioned sounds a bit different to this one: https://support.industry.siemens.com/cs/ww/en/view/88780011 Bye Murof |
4/23/2024 8:20 AM | |
Joined: 7/28/2016 Last visit: 4/16/2025 Posts: 15 Rating:
Still have no communication between PLC and PC also connecting directly PC to the CPU and also with simulator. In the attachment you will find my settings on TIA Portal Project and in the SCADA PC. AttachmentWinCC PRO V_19.pdf (335 Downloads) |
