1/17/2013 9:00 AM | |
Posts: 70 Rating:
Hi, how can I position the actuator using the library (see ST111.jpg) when I need to position the three positions? Thank you in advance for your answer |
1/17/2013 5:21 PM | |
Posts: 70 Rating:
The first, so I'm asking. Thank you in advance for your answer I will have to use three ST111, right? |
1/18/2013 8:12 AM | |
Posts: 70 Rating:
How? It is there only specify one value. Thank you in advance for your answer |
1/18/2013 9:39 PM | |
Joined: 9/16/2008 Last visit: 1/26/2023 Posts: 49 Rating:
Put in a tag Then write a new value to the tag when your moves are complete
1/19/2013 1:02 PM | |
Posts: 70 Rating:
Could you please clarify (see TIAportal_Sinamics_Lib_v7a.zip)? Thank you in advance for your answer
AttachmentTIAportal_Sinamics_Lib_v7a.zip (148 Downloads) |
1/19/2013 5:53 PM | |
? Not following But heres the setpoint |
