4/18/2014 11:41 AM | |
Joined: 2/28/2014 Last visit: 10/6/2022 Posts: 2 Rating:
you shoud reinstall tia portal and check your network property card.... |
4/21/2014 11:12 AM | |
Posts: 12 Rating:
i did. it's still same. |
5/9/2014 3:38 PM | |
Posts: 12 Rating:
i need still help about this topic. |
5/9/2014 3:46 PM | |
Joined: 1/5/2011 Last visit: 1/27/2023 Posts: 810 Rating:
If you are, make sure the proper drivers are installed, following link will help you install the drivers correctly: https://support.automation.siemens.com/WW/llisapi.dll?func=cslib.csinfo&lang=en&objid=37855423&caller=view I have installed following PC adapter USB driver with succes on a windows 7 64bit system: https://support.automation.siemens.com/WW/llisapi.dll?func=cslib.csinfo&lang=en&objid=6ES79720CB200XA0&caller=view Kind regards, Jens |
Last edited by: Jens_app at: 5/9/2014 3:54 PMadded SIMATIC PC Adapter USB Software V2.0 drivers Keep it simple and on-topic. |
5/9/2014 3:49 PM | |
Posts: 12 Rating:
No , im trying to connect by ethernet cable. (in network) |
