8/30/2006 5:13 PM | |
Posts: 8 Rating:
Hello Andrej, Maybe you have tried this already, but it seems it should work when you want to wait 120 seconds after finishing the subroutine to start the WARMUP cycle. To test part programs as if running on the machine, you may consider buying SINUTRAIN. This package is a simulation of SINUMERIK controls (802D, 810D and 840D) and runs under Windows XP. It does not have all NCK functions, but at least you can test run your part programs and see simulation as if on a real machine. Check: www.siemens.com/sinutrain and contact your local Siemens office (www.siemens.com/automation/partner). There is acheaper trial version available. Regards Daniel Kofman Siemens Netherlands |
