9/15/2010 6:13 PM | |
Joined: 7/28/2010 Last visit: 7/16/2023 Posts: 184 Rating:
Hosseini, That is called Hardware Interrupt. You setup your input card and it will trigger OB40. You can write your code in OB40 to capture the time. Take a look at the information for SM321-DI16-Hardware & Diagnostic Interrupt" which is attached. Regards, Behnam www.sigmaprocess.ca/blog AttachmentSM321-DI16-Hardware and Diagnostic Interrupt.pdf (64 Downloads) |
9/16/2010 12:59 PM | |
Hosseini, OB40 gives you the time it was called. Please take a look at the attached file. Regards, Behnam www.sigmaprocess.ca/blog AttachmentS7-OB40.pdf (66 Downloads) |
9/16/2010 3:54 PM | |
Joined: 1/28/2009 Last visit: 9/24/2023 Posts: 6821 Rating:
Thanks, very helpful |
