12/3/2007 4:26 PM | |
Posts: 51 Rating:
Hello |
12/4/2007 11:54 AM | |
Joined: 9/28/2005 Last visit: 12/14/2022 Posts: 414 Rating:
Hi, Am I correct that you used the sample program given in then FAQ How do you do the summer/winter time switchover with WinCC flexible?And you didn't add any code? If than still errors occure you should use the link Suggestion for the entry. |
Smurf |
12/7/2007 4:04 PM | |
Hi, If the MP370 would have an automatic daylight savings time like your windows computer has, I would agree with you. To bad this part of intelligence is not available in the panels, so some PLC code is necessary. Another possibility is the use of a time-server. If your PLC has a ethernet connection to a time server (NTP server) your problem is also solved almost without programming. See e.g. http://support.automation.siemens.com/WW/view/en/22144502 |
Smurf |
