1/26/2015 8:46 PM | |
Joined: 6/22/2013 Last visit: 4/5/2022 Posts: 141 Rating:
I want to use a DB for a timer and change times from a HMI |
1/26/2015 10:42 PM | |
Posts: 1058 Rating:
Hello diosnel, you will have to create a DB with timer parameters. If you use S5 timers the data type for the time parameters is S5TIME, if you use IEC timers data type would be TIME. For access of WinCC to these parameters look here: With WinCC, how can you access tags of the S7-1200 and the S7-1500 controllers? regards |
