10/9/2006 3:41 PM | |
Posts: 69 Rating:
Hi alibaba, do You meam the timers in Tag logging?? For what do You need so many timers. Normally i use 2-3 max. 5 timers? ?????????? Balu |
10/9/2006 3:53 PM | |
Posts: 90 Rating:
Go to Tag Managment and add a TAG where the address is a TIMERgreater than 511. You will get an error of overflow address. Regards, alibaba |
10/9/2006 4:18 PM | |
Joined: 9/27/2005 Last visit: 11/27/2007 Posts: 1398 Rating:
Hi alibaba This sounds like a bug with WinCC. Can you report it to the hotline using the Support Requestlink and let us know if there is a fix (or if it's working as designed) Regards, Salma |
