3/11/2013 7:30 PM | |
Joined: 9/23/2005 Last visit: 9/22/2023 Posts: 4235 Rating:
Hi, Many factors have influence in the program size. I know.Just for a first comparison, I mount a test with a simple logic (open contact i0.0 -> single coil q0.0), and repeat it many times.Here is the result. Note: each character in the coment takes at least one byte in the load memory of the S7-1200 and S7-1500 (butdoes not take place in work memory). The attached file compare the memory usage for S7-200, 300, 1200 and 1500. AttachmentC:\Users\z0008iwv\Desktop\Memory.zip (1093 Downloads) |
Last edited by: Pegaia at: 3/11/2013 8:02 PMLast edited by: Pegaia at: 3/11/2013 7:36 PMLast edited by: Pegaia at: 3/11/2013 7:33 PMDenilson Pegaia |
3 thankful Users |
7/26/2017 7:26 AM | |
Posts: 52 Rating:
Hello Mr. Denilson, Thank you for this analysis, the mentioned data in that sheet is in bytes or kilo bytes? |
