1/12/2015 6:36 PM | |
Joined: 9/23/2005 Last visit: 2/2/2023 Posts: 4177 Rating:
Hi, TIP: HMI should have version 13.0.1.0 or higher The Slide in could be configured on “HMI->Screen Management → Slide in”, in four types: Bottom Left Right Top It is necessary to activate the used type by setting the property “Enable” of it. You can call the Slide In screen with the function ShowSlideIn, or simply dragging and dropping the SlideIn screen in the desired screen. AttachmentSlideIn.zip (899 Downloads) |
Last edited by: Min_Moderator at: 1/13/2015 10:12 AMChange attachment name Denilson Pegaia |
6/16/2016 12:04 PM | |
Joined: 8/21/2014 Last visit: 2/3/2023 Posts: 713 Rating:
New question published by serge_pca is split to a separate thread with the subject How to access slide-in views with a KP (not touch screen)? . Best regards |
11/14/2016 3:43 PM | |
Joined: 9/3/2014 Last visit: 3/13/2019 Posts: 4839 Rating:
New question published by con ga is split to a separate thread with the subject Problem with rotary object in wincc pro( tia v13). Best regards |
10/30/2017 1:37 PM | |
Joined: 6/19/2017 Last visit: 1/27/2023 Posts: 6401 Rating:
New question published by JPol is split to a separate thread with the subject Is it possible to switch of Dragging but configure only action from pushbutton?. Best regards |
