7/20/2018 9:18 AM | |
Joined: 4/28/2015 Last visit: 1/25/2023 Posts: 385 Rating:
Hello, if you cause a hardware interrupt all the time, you maybe overload the CPU by doing this. And that is the cause, why it is not working. Isn't it enough for you, to set the comparison event to "equal or higher" and check this state of the counter in your user program, causing the reaction you want? For the counter of the module, check byte 14 bit 3 to do this... (see: chapter 4.3.5.2. of the 06/2018 manual) |
7/20/2018 12:15 PM | |
Hello, maybe this application example is interesting for you: Using the MC-PreServo and MC-PostServo organization blocks There is an encoder function block to generate position value from analog signal, using an analog input... Have a look... |
