11/25/2015 9:35 AM | |
Joined: 2/10/2012 Last visit: 3/10/2025 Posts: 315 Rating:
It seems the mail server replies to your plc that you use an invalid to: address. Eg. if you indeed used x@'example.com' in my example the mail server tells you that is an invalid address. Try using a known working email address. If you indeed get such a reply that means that port 25 is not blocked for you. Again try using your own email server first and wireshark to see what is really going on. |
11/26/2015 8:37 PM | |
Joined: 3/14/2014 Last visit: 2/13/2025 Posts: 6 Rating:
Thank you again for your reply. I got it to work. So now, do you know how to assign attachments? |
11/27/2015 9:37 AM | |
Great! You probably should open a new topic for that but I can end your dream here: The ability to do attachments is very limited. I tried it once and after having a lot of trouble getting a simple email running I threw in the towel early. My advice: Look for alternatives such as logging and recipes and xfer using the web server or if that doesn't fit use tcp/udp comms. |
11/27/2015 10:07 AM | |
Good morning "enof". Yes, probably a new trhead but.. Do you think it could be a problem with the ISP blocking attachments? I get an 8015 status when trying attachments, and I have tested many different things from "Structs" to simple "Int". The text i get in the "Daten"- buffer in the TM_Mail Instance DB is: '---$R$LContent-Type: application/octet-stream; name="Attachment.bin"$R$LContent-Transfer-Encoding:BASE64$R$LContent-Disposition: attachment; filename="Attachment.bin"$R$L$R$L' |
11/27/2015 11:32 AM | |
No, likely not an isp/smtp server prob. I gave you an advice and "enof" has enough;) It seems you already have a data log. Pull it from the webserver, include the url in the mail or use email to push-automate a pull instead of trying to attach. Trust me (or not) , been there done that. In case you get anywhere with attachments please let us know but I wouldn't be surprised if this is the end of this topic. |
12/10/2015 3:38 PM | |
Joined: 9/3/2014 Last visit: 3/13/2019 Posts: 4766 Rating:
New question published by DanielLC is split to a separate thread with the subject TMAIL_C and TM_MAIL function blocks. Best regards |
