5/4/2012 10:35 AM | |
Posts: 13 Rating: (0) |
Hi, when I run the cycles (attached), the first part runs in circles. I have checked if the .Q on TON timer changes from 0 to 1, what happens, but the cycle doesn't move further to the next step. Expected behavior is cast0 starts, then ends and cast1 starts etc.. Any suggestions? thanks in advance spok Attachmentcycles.zip (442 Downloads) |
5/4/2012 10:38 AM | |
this is the printscreen from mentioned part... |
5/4/2012 1:36 PM | |
here you can see that the .Q on TON is triggered, but doesn't cause execution of the required network. |
