3/13/2014 10:19 AM | |
Joined: 4/24/2006 Last visit: 12/1/2023 Posts: 8596 Rating:
Hello MPJR, Are you using Multi Instance blocks? how can you reduce memory usage with Multi Instancing? Best regards, Wizard |
3/13/2014 10:21 AM | |
Posts: 8 Rating:
Yes it is multi instance, but the FB is just called once. The cycle time of this project is 11-15ms. |
3/13/2014 10:36 AM | |
Mmmm weird What version of TIA Portal are you using? Best regards, Wizard |
3/13/2014 10:44 AM | |
Posts: 8 Rating:
TiaPortal V12 SP1 update 3 |
3/13/2014 10:54 AM | |
Here you can download latest update: Updates for STEP 7 V12 SP1 and WinCC V12 SP1 Best regards, Wizard |
3/13/2014 10:57 AM | |
Posts: 8 Rating:
Thanks. I haven't notice that update, cause I was waiting the V13. I will test that. I also put V13 to download and try that also. |
