8/6/2020 1:45 PM | |
Joined: 11/28/2019 Last visit: 10/8/2024 Posts: 3 Rating:
Hello, I have problem with message about "Too many powertags used". I used WinCC Runtime Advanced V15.1 on IPPC-6172A Industrial Panel PC. Runtime, visualization and communication with S7-1500 working fine. Link with Screenshots of configuration and Licence attached below: [snip] So, despite the license and the use of <512 tags, the message appears. Any suggestions? Thanks. Edit: [SOLVED] In my case the problem was a not original licence delivered by the client. When the original licence have been installed, pop up disappeared. Attachmentwetransfer-adc61c.zip (61 Downloads) |
Last edited by: Jen_Moderator at: 08/06/2020 14:06:56Removed link and added file as an attachment. Last edited by: Rafal_C at: 09/15/2020 21:52:51 |
8/12/2020 4:22 PM | |
Hello Perhaps you have a problem with ALM You can try to use the latest Version: https://support.industry.siemens.com/cs/de/en/view/114358 Bye Murof |
8/13/2020 10:43 AM | |
Joined: 7/23/2019 Last visit: 4/17/2025 Posts: 2 Rating:
hello, I have the same problem. Although I installed the latest version of ALM. |
